Results 1 to 8 of 8
Thread: Raypak RP2100 - Can't Activate Remote
    So this season I have been unable to activate the remote to my Raypak RP2100 pool heater. I can turn on the heater from the front display, however when I press and hold all three buttons on the keypad the display will move to "REMon" but as soon as I let go of the three buttons the display immediately returns to "REMoff"
    This has become increasingly frustrating...any suggestions??
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Raypak RP2100 - Can't Activate Remote
    Sorry, can't help...
    While you have either REMon or REMoff displayed, you can press either of the temperature buttons once to change remote modes.
    Northern VA
    59
    i have the same problem and have had no success making the change - any ideas? No matter how quickly/ or slowly I try to push the up or down after the display changes to REM it remains as REM off.
    Thanks
    Sean
    Sean
    15 x 30 gunite pool with Riverflow Professional 12miles per hour flow (10HP silent ABB pump) to make the entire pool flow - Pentair Intellitouch i10 - Heat pump AquaComfort 110 - Raypak 399k Digital Gas Heater - Pool Pilot Digital SC-48 - Pentair FNS Plus 60 - Polaris 3900 Sport Cleaner on booster pump
    2 x Pentair Intelliflo pumps - one for filter (VF) and second for Venturi Pool Jets (VS) and Jandy 6 set deckjets - Pentair PG2000 Fiberoptic lighting - Automatic PoolCover (Brown) by Pool Cover Specialists
    Winter Pool Bubble by Ameri-Dome
    Mar 2011
    441
    Rem off = remote mode active, but nothing calling for heat.
    Unless there is something hooked to the remote wires on the back of the control board (common to pool/spa) there will be nothing to activate the external remote on the heater.
    20X40 30,000 gallon gunite pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    How long are you holding the 3 buttons down? They need to held down for at least 5-7 sec.
    Factory Warranty Station for:
    Northern VA
    59
    Pool Clown - holding for at least 8 to 10 secs and even longer - just defaults to Rem OFF.
    racket - the heater has worked for a year and just changed after a power outage. it is connected to the intellitouch and it is calling for heat according to it. Any other ideas as this is very confusing.
    Many thanks
    Sean
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Disconnect remote wires from the plug, and use the firemans switch loop (red wire loop with printed sticker wraped around it. Cut the loop and use those two wires to remote control the heater with the i10.
