Results 1 to 10 of 10
Thread: Required Testing By Builder
    Jun 2011
    Jensen Beach, Florida
    22
    My pool builder is going to require me to have a print out done by Pinch-a-Penny pool supplies once a month. They say it is to keep warranty of the Pebble Tech finish. The warranty is lifetime.
    I wanted to ask if anyone has experience with this company, and what they will charge me for this print-out of water test.
    10k gal pebble tech, intelliflo vs pump, ic40 swg, dynamic filter
    Re: Required Testing By Builder
    Normally they will do it for free on the hope that you will buy something when you are there. Every once in a long while you will run into a store employee who is grumpy about it, but generally they are more than happy to help out. The challenge is to get out without buying anything you don't need.
    22,539
    It has to be Pinch-a-penny? If so, I'd say there's more to that than meets the eye! (you scratch my back I'll scratch yours). As Jason said, most of the time they're glad to do it. And you can buy some of your needs there from time to time.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Here's my read on this:
    PB wants to be sure you don't chemically abuse his warrantied finish. He doesn't trust you to test the water, or report it accurately. I'll give him the benefit of the doubt and assume he believes that Pinch-A-Penny will test the water for free and give you a print-out. He wants documented proof that you followed his chem level requirements, if you don't provide them, he can invalidate his warranty.
    However, what he and P-A-P don't know is when the sample they test was taken If you want to play the game by our rules, but doing so might invalidate your warranty - fill a couple of jugs with pool water that tests 'within range' and store them in a cool dark place. When you have to have P-A-P test the water, use that. You might want to add a drop or so of bleach to the ~ 1 cup sample you bring or dilute it slightly with tap water, so the numbers aren't always the same
    Luv& Luk
    -Ted
    Donldson's Avatar
    NW Ohio
    2,880
    I don't know if you would have to cheat. Did the PB say that you had to follow the store recommendations or just that your numbers had to be in an acceptable range? As long as you check it yourself before and everything is in spec, the store shouldn't show much difference and you should be able to ignore their sales pitch without risking your warranty.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2011
    22
    I was so excited to find this site, knowing I would be able to care for my new pool myself. (With all of your help of course.) Then to be told I had to test with a single dealer, I was put out. I do get the warranty issue, and understand if wrong I can ruin the finish. I will abide by the PB's regulations. Guess I will even buy needed items from P-a-P. After a visit to my local P-a-P, they do test for free. I had the same ideas you all had about ulterior motives. Hopefully with everyone's assistance I'll have perfect water every time. Figure if I test with my TF100 before going, I'll make sure.
    Thanks again to all.
    Pictures of build coming soon. Permit applied for yesterday, and expect excavator on July 5th.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I am not a lawyer, but I am going to suggest a quick read of the Magnuson-Moss Warranty Act (15 U.S.C. ch.50 § 2301 passed in 1975), specifically regarding lifetime warranties and tie-in sales.
    http://en.wikipedia.org/wiki/Magnuson%E ... rranty_Act
    Jan 2011
    Albuquerque
    72
    Just a thought: Could you not perform and track your own testing along with the PaP testing? If you provided the PB with MORE detailed and more frequent testing results (via TF-100), he might realize that you are not the typical hands-off pool owner and relax on this requirement a bit.
    Jun 2011
    22
    I will inquire about providing my own test. I do know that P-a-P provides a print out. Pretty sure it will be up to Florida Jems pool finish and not the pool builder.
    By the way Ohm-Boy, the way they get around that is there are no purchase requirements from P-a-P for their testing.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    True, but there may or may not still be an unlawful business tie-in. To say that if you get your water professionally tested at Leslies, or some other business which provides as reputable a service as p-a-p, then we refuse warranty service, is, in my opinion, unlawful in light of the intent of the warranty law, as it places the focus not on whether the water was properly cared for, but instead on where the water was tested. But as I mentioned earlier, I am NOT a lawyer, and nothing I say should be construed as legal counsel or advice.
