Thread: Little ants going under bottom rail.
    Apr 2011
    Ohio
    97
    So, in 4 days time, I have ants digging under the bottom rail of the new pool install. It is just those really little ants, but it looks like they moved a little bit of the sand from under the liner, to the outside of the pool wall. Any suggestions on how to keep the away from the pool? You never realize how many ants you have in your yard, until you dig half of it up to build a retaining wall, drainage, and pool. (This is an AGP)
    I know I can't kill them all, or I would, but I would like to keep them away from the pool wall. I don't feel like having them dig tunnels throughout my sand bottom
    14.6K gal., 24ft, 54" above ground. 2HP, 2speed Hayward pump (4psi low, 18psi hi), 150sqft cartridge filter. 4x20 solar panel (6 psi).
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Little ants going under bottom rail.
    Try sprinkling DE (diatomacious earth) around the bottom rail (*as long as no kids nor pets will get into it) and you might just kill them all.
    Luv& Luk
    -Ted
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by waste
    +1
    DE will get on them and leach the moisture from their little ant bodies, thereby killing them.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Boric acid also works. They take it back to their queen because they think it's food. Kills em dead. 20/20 MuleTteam works just fine. Pour it on their little hills, they will haul it underground and die. They like it. muuuhahahahahaaaaa
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
