Thread: WOW FC Dropped
    Mar 2011
    Houston, TX
    72
    WOW FC Dropped
    Yesterday FC was 5.5. Removed the tabs from the chlorinator and checked this evening and I was down to 3. Just added 269 oz of bleach to bring it up to 10. I have a high CYA of over 100 so I am maintaining a high FC until I can replace water.
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Re: WOW FC Dropped
    With CYA over 100, you never want to let FC fall below 10. Letting FC go lower risks algae, and once you get algae it will be exceptionally difficult to get rid of unless your bring CYA down.
    Mar 2011
    Houston, TX
    72
    Re: WOW FC Dropped
    how long should I wait to retest?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: WOW FC Dropped
    Quote Originally Posted by brownchristian
    About an hour, with pump running.
    You're done SLAMing when:
    Mar 2011
    Houston, TX
    72
    Re: WOW FC Dropped
    Retested and I am at 12 now. Water looks great. Wish there was an easier way to lower CYA cause its almost a sin it to remove this water.
