Thread: Would this work?
    Apr 2010
    Western North Carolina
    44
    Would this work?
    I was just reading a thread on Pool Chillers. I know that a hole in the ground is much cooler than air temp. (My basement stays at least 15 degrees cooler) Has anyone ever dug a hole in the ground several feet deep and coiled water lines in it and covered it up to cool their pool?
    24' X 52" AGP - On a concrete slab with 1" Dow blue foam board bottom.
    2Hp 2 speed Waterways pump/Cart. Filter.
    Hard Plumbed 20' away
    Deck 1/3 around pool
    Pool Rover Jr.
    DIY project
    Best Pool Store Quote, "THAT BLEACH WILL DESTROY YOUR LINER."
    Re: Would this work?
    Something along those lines can work, but a small hole such as what you describe would never work. A ground source heat exchange system typically requires something like a thousand feet of trenching, or a well of similar depth, and a heat pump to work.
