Thread: Non Doughboy Liner in Doughboy Pool
    Guest
    Hello, we have a little Doughboy pool with their E-Z Clip beaded liner that needs replacing.
    A genuine Doughboy liner while great is a bit steep for us right now at around $400 delivered for an 18' pool that will probably be used a couple more seasons.
    I've been trying to find other liners that may work, but haven't had much luck. All the places I've called initially say that yes they have a beaded liner that will work, but then back off and say they can't be sure or probably not. I know nothing about liners other than this one, so I have no idea what the differences are between different beaded liners.
    Does anyone have any experience with using a non Doughboy liner in a Doughboy pool with the EZ-Clip system?
    Thanks for any advice or comments
    Feb 2008
    Denton, TX
    5,061
    Re: Non Doughboy Liner in Doughboy Pool
    Welcome to TFP! Someone will be along shortly to help you with your question.
    Guest
    Bump ... Thanks for any input!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Pocono pool products can send you bead samples that you can compare your current liner too. Also you can just purchase j-channel track ans install that on the pool wall and then order a liner for that. I would try the bead samples first
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Guest
    Thanks, I'll give them a try.
