Results 1 to 12 of 12
Thread: wrinkles in Intex Ultra 24'x52" pool
    May 2011
    East Texas
    11
    I set this pool up about a week ago and there were no wrinkles in the bottom. I noticed yesterday that there appears to be wrinkles forming in the bottom now. The pool is set up on the 3/4" blue foam from Lowe's. Any ideas what caused this to happen?
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    Re: wrinkles in Intex Ultra 24'x52" pool
    What temperature do you think it was when you filled the pool? If the liner warmer up and stretched out and you put cool water in it, or the water cooled down, it can cause the pool to shrink alittle then later expand when the water warms back up causing wrinkles.
    5,061 Gallon 16' x 48" Intex Metal Frame Pool
    14" Intex 55Ib Sand Filter and Pump.
    _______________________________________
    Location: Columbus, GA Where the Heat and the humidity are* :)
    May 2011
    East Texas
    11
    I am sure it was between 95 and 100 when I put out the liner and straightened it becasue that is how hot it has been everyday for the past 2 weeks. I did not fill the pool all at once so I don't think it would be cold water causing it to contract and then strecht out later. Kinda aggravating though.
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    I'm sure it is upsetting. Another reason could be that the pool settled while filling. That could cause wrinkles. What did you use to level it?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    The same thing happened with our Intex pool. Over the summer, as they stepped and pushed on the bottom more formed. And now after leaving it up over the winter even more have formed. They catch the sediment though. Makes it easy to find the dirt while vacuuming...
    We tried to smooth them out by holding kid feet while they snorkeled and pushed at them underwater when we drained half the pool to lower CYA last year, but it's not easy so we gave up. It doesn't seem to affect much except sediment anyway. Probably should have used one of those foam pads everyone here talks about instead of sand on top of previous pool sand. <shrug>
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    I have the same problem too, not too worried about it.
    Going on 4 years now through winter and all, I'm just waiting for it to bite the dust someday for an excuse to get a bigger pool.
    It does make vacuuming easier though even if it doesn't look perfect!
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The trick is to stretch as you fill, in steps as the water rises. It takes some time and patients, but its the only way. You'll still get some very minor ones, but I can live with these. Big ones annoy me to pieces.
    Essential Links:
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Quote Originally Posted by Brushpup
    thats the way i did it. ended up with only a few minor wrinkles!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by jsf0656
    Dang! Sorry then, I wish I could offer more help to you. You only have two choices, and I like neither....
    Im really not that Ignorant about my spelling, but sometimes I don't catch the auto fill on my phone. Stupid me....
    Essential Links:
    May 2011
    East Texas
    11
    After closer inspection, I have not been in the pool in 4 days, it appears that they may not be wrinkles at all. Over the weekend we had a wildfire close to us and there was ash falling for 2 days straight. It looks as though what I thought were wrinkles forming were actually just lines of ash sattling on the bottom of the pool in strange lines. Whew!!!
    carterj92's Avatar
    Jun 2011
    Columbus, GA
    90
    Quote Originally Posted by dpman79
    lol Thats great to hear! Well, not the wildfires but the fact that there aren't any wrinkles!
    May 2011
    East Texas
    11
    yeah, but I will not be 100% positive there aren't wrinkles until I get back into the pool. working on getting the SWG worked out right now.
