Thread: How long to run filtering?
    Hi,
    I have a 20000 gallon in ground pool with a 1.5 hp motor and sand filter. How long should I run the motor during every 24 hour period and is it best to run it at night or in the day?
    Dave
    OzarkMark
    [sub:3gts0njy]Summer Escapes 16'x42" - Sunshine 1600 Sand Filter & Intex Krystal Clear SWG[/sub:3gts0njy]
    Aug 2010
    Dallas, TX
    4,052
    Re: How long to run filtering?
    I've posted you a link to get you started.
    pool-school/pump_run_time
    It depends more on the flow of the pump than the horsepower.
