Results 1 to 9 of 9
Thread: outdoor refriderator
    Jul 2010
    Mickleton, NJ
    229
    Not sure if this is the right place for this or not. I'd like to have a fridge outside so we can have drinks, cheese for burgers etc. on hand. We would probably bring it inside once we close up the pool and put it out in the spring when we open. Anyone have any suggestions on a small fridge? Looks like prices range from $350 to 3,000.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    22,553
    Re: outdoor refriderator
    A small stainless steel unit would probably do best. It doesn't make a lot of difference in the brand until you get into the high end units but unless I was going to get an outdoor rated unit I'd go with the cheapest stainless unit I could find.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,091
    We have a small 4.3 cub ft GE stainless steel fridge and it seems to work great. I think it is about $200 at Best Buy.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    I have a small (not the smallest but next size up) dorm size fridge under the bar outside which is on the shady side of the house, works out great!
    I keep food, adult beverages and condiments in there for easy access while grilling.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    no-mas's Avatar
    Jun 2008
    FL
    405
    x2 - get the least expensive one you can find, and replace as needed. I'm going on 4 years with my <$100 home depot SS fridge... I'm so happy I decided not to buy an outdoor rated one. Looks perfect still, and if it falls apart, who cares - I;ll just replace it.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    nutjob's Avatar
    May 2011
    Dallas
    109
    My outdoor refrigerator is a Danby DAR482BLS 4.4 Cu ft model with a stainless steel finish. It's more of a small office fridge but it is rated for outdoor use. It does not freeze ice cubes but keeps drinks cold and food in the safe zone under 40°F.
    Best of all it was about US$250 brand new and looks professional.
    My neighbors are suitably impressed yet have no idea how little I spent. (Good thing they're not on this forum!)
    I laughto disguise the tears.
    Size 15,000 gal 510′ | Filtration DE 48′ | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33N 97W)
    Jul 2010
    Mickleton, NJ
    229
    So, I don't really "need" one that is rated for outside use? I'm not sure if I could get it in the shade or not, I may put a bar in eventually and could keep it under cover there but for now it may just go on the deck so it could get rained on, would this be safe if it is not rated for outdoor use?
    Currently Pooless
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by melissab
    Ignore my advice, then. I keep mine outside, but in a covered patio, under a bar counter. It is subject to more temperature and humidity extremes than in indoor unit would be, but certainly isn't directly exposed to the elements.
    Hopefully others have different experiences to share...
    22,553
    Setting it on the deck where it's completely unprotected, I'd want an outdoor rated model. Indoor models have the electronics where rain could drip on them and ruin it.
