Thread: Dumb Testing Question
    Mar 2011
    Houston, TX
    72
    On the CYA test should I cut the tip off the bottle so I can squirt it in the tube or just pour it in without the top?
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Aug 2010
    Dallas, TX
    4,052
    Re: Dumb Testing Question
    cut the tip off, although I've done it the other way it makes it harder to slow down when you start getting close.
    Donldson's Avatar
    NW Ohio
    2,892
    There are no dumb questions here. Just dumb pool store suggestions that get shot down
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
