Thread: Is this set up too much for this pool?
    Jun 2011
    North Jersey
    8
    Will a 15' x 42" Intex Inflatable Ring pool support a Hayward EC30 and Hayward 0.75HP pump?
    Allegedly 3200gallons.
    Has anyone put the bigger hoses/adapters and shut off valves on the soft sided inflatable ring pool?
    Where did you get the adapters?
    Thanks!
    15' x 42" Intex Easy Set Blue Blob AGP, 3100gal, Intex SWCG Titanium
    Hayward EC-30 DE/40GPM
    oldman's Avatar
    Jun 2011
    Boothwyn, PA
    7
    Re: Is this set up too much for this pool?
    I use to have a 18' X 48" softsided Intex pool with a Pentair 100 lbs sand filter with a 3/4 Hp and that worked great for years. Yes it is big for that pool, but It will filter out quicker. As far as for the adapters I used the inch to inch and a half fittings coming from pump to filter with clamps and ran two 6' hoses from the pool and a 3'foot hose from the pump to the filter and that worked great. Instead of using Intex adapters from the hoses Intex gives you, (mine had the shut off valves) I just hooked up the hoses with clamps. If you don't have the shut off adapters and the in take and return are straight out, you will have to support the adapters so that there is is not hardly any vibration so the sides don't tear.
    18' X 52" Intex Ultra Frame Pool about 7,000K with a Haward DE Filter Hayward Power Flow Matrix 1 HP 2400 GPH Pump
    Jun 2011
    North Jersey
    8
    Thanks Oldman! Didn't think about supporting them to avoid tearing. Had to drain the pool yesterday, as it was starting to creep, and the water was about to top the ring on one side. Not sure what happened, thought I had it down to 1" off over the
    15' using a string level. Will level it out and go forard with swapping in the Hayward pump filter this week.
