Results 1 to 13 of 13
Thread: My first pool
    Jun 2011
    Williamsville, NY
    4
    My first pool
    We just bought our first house and it came with a pool. Our pool has been open a couple of weeks now and I just finished a 3 day shock session to clear out an algae overgrowth. The pool is no longer green but it is still cloudy. I have a chlorine and pH test kit that came with the pool. The pH is 7.4, which is supposed to be ideal and the chlorine is at 2.5. I brushed the pool daily throughout the shocking and continued to do so once the green was gone. I have been trying to vacuum it but my hose won't stay on the vacuum for more than 1/3 of the pool at a time. I just want to be able to swim in my pool.
    17,100G sand AG unknown filter size
    Re: My first pool
    Welcome to TFP!
    How has the filter pressure been behaving, and have you needed to backwash the filter during this process? Also can you describe the water a little more, for example what color is the water?
    Posting a full set of water test results would help a great deal. Ideally you should have your own test kit, but a full set of results from a pool store will do.
    Jun 2011
    Williamsville, NY
    4
    Re: My first pool
    I will be picking up a six way test kit as recommended later today. For now, the water is blue-cloudy and I have had to backwash the filter several times a day since I started; except for it was fine this morning and seems to be needing it less.
    Re: My first pool
    That sounds very promising. Hopefully another couple of days and everything will be all cleaned up.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: My first pool
    Patience Grasshoppa!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: My first pool
    Welcome to the Forum! Sounds like it is well on the way. Lets know how it goes.
    Essential Links:
    Jun 2011
    Williamsville, NY
    4
    Re: My first pool
    How do i add the baking soda to my pool? through the filter basket, or just pour it around right in to the pool?
    Aug 2010
    Dallas, TX
    4,052
    Re: My first pool
    It doesn't sound to me like you are finished shocking. Did you read through the shock process in pool school?
    pool-school/shocking_your_pool
    Jun 2011
    Williamsville, NY
    4
    Re: My first pool
    yeah, shocking is now done and i had a water sample analyzed. my cya was zero so i fixed that and now i need to boost my ta from 40 but i am unsure of how to add the baking soda to my pool.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: My first pool
    You can just broadcast it over the pool surface.
    Aug 2010
    Dallas, TX
    4,052
    Re: My first pool
    Blue cloudy doesn't meet the criteria for completing the shock process, but I'd say it is nit-picky. If you didn't measure your overnight chlorine loss, you don't have a way to know if your shocking is complete. I noticed you said you were picking up a test kit, so I am making the assumption you didn't perform an OCLT. I would hate for you to get this far and not complete the process, and end up having a chlorine-eating monster on your hand.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: My first pool
    It's not nit-picky....You're done shocking when: 1)You lose 1ppm or less FC overnight, & 2)You have .5ppm CC's or less, & 3)your water is clear.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: My first pool
    Seems like there's more time, chlorine, and energy wasted in not using the above three rules for shocking than there ever would be if they were followed.
    So... no, not so nit-picky when you consider the added misery that missing the shock boat lands you with.
    OP is also getting a 6-way kit. The most prevalent one of those is the HTH kit which does not test for CC and as such, rather useless when there's an algae issue. The only reason it's called 6-way is because it also tests for bromine. There's your 6th way. It's actually a 5-way kit.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
