Thread: Cya & dichlor
    Jules's Avatar
    Jun 2011
    Kemp, Tx
    111
    Cya & dichlor
    Just bought our pool and set it up last week. I'm using the BBB method, everything was good, except I didn't add CYA when I started up. I've been losing chlorine like crazy, and I know that's the reason. I only have the 6way drop test from walmart, as of right now.
    I added CYA yesterday, in a sock and put it in my skimmer basket. I added 1.75lbs, which was the whole bottle. I know I need more, but the pool store was closed.
    My question is this, the 1.75lbs was only about half of what I need. What damage would I do if I switched to Dichlor to get my cya the rest of the way? Kids are bugging me to swim, and the cya is taking forever to dissolve.
    Thanks for any help y'all can give me! I hope I made sense.
    -Julie
    25,600gal/33' x 52" Sharkline Heritage, Pentair Clean & Clear 150sq ft filter, 1.5hp dual speed Optiflo pump, TF-100 test kit, BBB method, Pool Rover S2-40
    Re: Cya & dichlor
    Welcome to TFP!
    First, they can swim as long as the FC level is appropriate for your best guess at what the CYA level is.
    Using dichlor is just fine as long as you keep track of what it is adding. Dichlor adds chlorine, adds CYA, and lowers PH. One good way to approach this is to calculate how much dichlor you need to use to raise the CYA level by the desired amount and set that much dichlor aside for use raising the FC level. Then actually add the amount of dichlor you need to raise FC the correct amount, until you run out of dichlor. Remember the keep track of the PH while using dichlor. You will typically need to add soda ash/washing soda every time you add dichlor to keep the PH balanced.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Cya & dichlor
    You can add CYA slowly that way. You don't want to try to get all the cya from dichlor in one application or it will take a while for the FC to drop low enough for the kids to swim.
    The kids can swim now while the cya is dissolving. Just treat the pool as you would if the cya you added was showing up on a test. You can add liquid chlorine to supplement the SWG until it keeping up with demand.
    Love TFP? Become a
    TFP Supporter!
    Jules's Avatar
    Jun 2011
    Kemp, Tx
    111
    Re: Cya & dichlor
    My TC is extremely high right now, and I can't measure FC with the test I have. I added 314oz of bleach yesterday (my chlorine level was 0) to hopefully reach shock level. I figured that since I didn't have any cya in the water it would just burn up anyway...hopefully I'm right I think I'll just stick with the cya, it seems easier.
    ETA: I added all the bleach because I thought algae was the reason for my chlorine drop, even though the pool is crystal clear. After I added the bleach last night I checked the level and it was bright orange (hth drop test), checked again this morning and it was still the same color. I didn't realize that not having cya could in fact cause the sun to eat through my chlorine in a couple of hours. I feel like I'm messing up so bad, this is a little overwhelming at first!
    -Julie
    22,553
    Re: Cya & dichlor
    It's a little overwhelming to begin with but if you keep reading here and keep practicing what you read it'll get simple in no time.
    I suggest that you get the TF-50 kit from tftestkits.net. Since you have a OTO/pH kit it'll be a perfect addition for you.
