Thread: I'm confused about above ground pool dimensions.
    Is a 24' pool, 24' across or 24' round? I have a small back yard and I'm trying to figure out what size of pool will fit. I'm looking at Intex 24'x52" and 18'x24". Thanks
    1) 7500 Gallon Free Form Gunite Pool / 800 Gallon Gunite Spa
    2) EasyTouch 8 Automation / IC20 Intellichlor
    3) Intelliflo VS Pump for pool and water features - Cartridge and DE Filter / 2 Speed Pentair Pump for Spa and Cartridge Filter
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: I'm confused about above ground pool dimensions.
    It's roughly 24' across.
    My 15' Intex comes to about 14' 8"
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Thanks alot. I may be able to squeeze in the 24. That's the only size I can find with a good powered pump.
    22,553
    Mine's just a little bit bigger than 24' across when measured to the extreme outside of the top rails.
