Thread: How to measure
    Mar 2011
    Houston, TX
    72
    How to measure
    What do you guys use to measure bleach and acid, etc....? Today the pool calculator told me to add 75 oz of acid and I had to look up an OZ to Gallon converson to figure out how much of the bottle to add.
    18,500 gallons, Cartridge Filter, In Ground Plaster. Jandy CL460 Filter
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: How to measure
    When I add liquid chlorine I use a glass measuring cup.
    I also have a an 8 cup pitcher with lines marked at every 8 oz. that I use for bigger quantities .
    I guess a 5 gal. pail would work out well too with lines marked at every gal.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: How to measure
    I have one of these.
    Plastic, won't break. Can be read looking down from above from the inside out, so you can keep the acid down low. http://www.lesliespool.com/Home/Pool-Ch ... 14491.html
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Re: How to measure
    I use a 1 quart plastic measuring cup similar to Richard. (I think I got it Walmart or Target someplace like that). I take a 5 gal bucket with some water and add my chems to that. That way when pour the bucket into the pool, I have some control over how fast I'm adding stuff. Just place the whole bucket into the pool, then tip it to slowly pour out the contents in front of my deep end return.
    I was a little worried about using plastic when adding acid too. But, the cup didn't melt or anything, it worked a champ. I have one of those OXO ones you can read from the side or from the top, that way I can keep the cup low and still read it like Richard said. I'm not a big fan of glass by the pool. I had a pyrex measuring cup for awhile, but just got nervous I would break it and get glass in the pool. I'm not fan of any glass by the pool frankly.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    22,542
    Re: How to measure
    I also have a plastic pitcher with graduations and it's fine for most things.
