Thread: Solaxx® SafeDip™ Digital Water Chemistry Tester
    Apr 2009
    Burlington, ON, Canada
    Anyone seen or tried this? I know digital testers are frowned upon (I have a k2006 and quite like playing mad chemist, but I also like gadgets)...mind you, this one doesn't test TA or CYA.
    and here
    I see one review at and it's negative (says it couldn't read chlorine level). I might pick one up and test it out - I can compare it to the results from my k2006. If it doesn't work Costco will take anything back..
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star 1HP (1.85) pump, Hayward sand filter
    Nine Fafco Sunsaver 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Re: Solaxx® SafeDip™ Digital Water Chemistry Tester
    It is basically a PH and ORP meter, with a few extras. If you look around, there are many of them. ORP readings are not especially useful, and none of the electronic pocket meters seem to last very long in actual use.
