Thread: 20,000 fiber glass pool
    I have a 20,000 fiber glass inground pool that is green and need to dump the water with a submersiable pump from Home Depot, I checked the Cyanuric Acid levels and it was around 140. Once I dump the water with the pump and refill, how much Cyanuric Acid do I need to add to the skimmer, and when I use the pump from Home Depot, how would I use it considering its electric and its in water?
    Also I have De Micro Clear Filer De 6000, and I constantly open it up and clean it out because of algae. After I clean it it goes blue, then back to green in a few weeks with out chlorine.
    How much chlorine should I be adding every week? A pack of shock a week?
    Location Southern California
    Uploaded with ImageShack.us
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Re: 20,000 fiber glass pool
    It's a sump pump, they are designed to be in water. Also have a idea have many feet of hose you will need they will furnish that too. Dumping about 3/4 of your water should get you under 40 cya.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Mar 2011
    Florida
    179
    Read through the pool school while you are refilling the pool. And after filling be ready to post a set of your readings. That's the first thing you will need to really get good help.
    is there a link to refill pool in pool school, i didn see it.
    22,551
    I don't remember a specific article about refilling but the best thing you can do s read pool school and get a good test kit.
    There is no set amount of chlorine you need to add each day or week. You need to test and add enough to keep the FC above the minimum for your CYA.
    Learning to use the Pool Calculator is a good thing to do and it will give you quantities to add once you enter the now and target levels.
