Results 1 to 8 of 8
Thread: New user with (hopefully) a minor question
    Jun 2011
    Southern NH
    26
    Hello to all
    I do not yet any test kit of any kind (would love to have your recommendation). Right now I do not have any test results. My water looks good and we did have it tested two weeks ago and we got loaded up on chemicals at the pol store to bring the pH level into range. The only problems I am having is the water feels sticky. Crystal clear water, just a bit sticky.
    Any thoughts on that would be great along with my best bet for a test kit so I can get the results to post here.
    Thank you in advance.
    JoeFixes
    (but only if it is broken!)
    18x33 AG - 15,700 Gallons
    DE Filter
    Feb 2008
    Denton, TX
    5,061
    Re: New user with (hopefully) a minor question
    Get yourself a TF-100 from www.tftestkits.net. This is the best kit with the best value that you will find.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Ditto. Might as well splurge for the XL option, cause you'll be burning through a lot of reagent at first playing with the new toy. And a speedstir. Nobody who has bought one has said it was a waste of money. wow-taylor-speedstir-is-so-cool-t21072.html
    Jun 2011
    Southern NH
    26
    Hey Guys,
    Was hoping you could tell me if this link to the test kit sold on Amazon is the same kit that is sold at tftestkits.com
    http://www.amazon.com/Taylor-Complete-F ... 370&sr=1-1
    I get free shipping at Amazon so it would be a bit cheaper, but if it is not the same thing then its not worth the savings. Your help is greatly appreciated.
    JoeFixes
    DE Filter
    Hopefully, I can post this link correctly. This will show you the differences between the two kits. That's what I did to make my decision after looking on Amazon, & ended up going with the TF 100. Take a look & see which is better for you.
    pool-school/pool_test_kit_comparison
    8800 gallon AG, sand filter
    SoCalGary's Avatar
    Mar 2010
    Orange County, CA
    9
    You can't go wrong with the TF-100. It really is a fantastic test kit that put me back in control of my pool. Oh and +1 for the SpeedStir. It's a great little time saver.
    17K Gal. IG Vinyl - 1.5 HP Pentair WhisperFlo Pump - Pentair SMBW 4048 DE Filter - Solar Heating - TF-100 Test Kit
    Pool School - The Pool Calculator - How to Shock Your Pool - Help Support This Great Site!
    Sticky water, ick. If you can recall what sort of stuff the pool store sold you, maybe someone can point out the culprit.
    I'll take a wild guess it was an algaecide, but I've never used one so that is a guess. I hear of them creating foaming and bad smells and so that seems like it would start out sticky.
    Following the method used on this forum, you won't need expensive sticky potions from the pool store. I use chlorine (3 varieties) and acid. No floc, no clarifiers, no algaecides, no enzymes. When I need calcium I use chlorine with calcium (cal-hypo). When I need CYA I use chlorine with CYA (trichlor pucks). When I need just chlorine I use bleach (most of the time). And since I have fill water with high TA which pushes my pH up, I use muriatic acid to keep pH and TA in line. No other chemicals.
    Pretty simple and really cheap. I like simple and cheap pool care.
    Jun 2011
    Southern NH
    26
    Thank you!
    Probbaly makes sense to go with the one recommended.
    JoeFixes
    DE Filter
