Results 1 to 10 of 10
Thread: Switching from Salt system back to chlorine tablets...HELP
    I have had a salt system on my pool for the past 4 years. It has been replaced 4 times due to failure. I have had it and I am switching back to chlorine tablets. I had a guy tell me at the pool store that to do this I will have to drain at least half of the water out of the pool and refill it with fresh water before switching to chlorine tablets. can anyone offer any advice? is this true? what do I need to do to switch back to chlorine? has anyone done this before?
    Thank you
    Mar 2011
    Hazelton, PA
    57
    Re: Switching from Salt system back to chlorine tablets...HE
    Garbage... Just start adding tabs and watch your CYA
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    At least they didn't try to sell you a whole new pool!
    The pool store is probably worried about your CYA level. For the SWG the CYA level should have already been as high as you should ever let CYA get. Using tablets will continuously add more CYA to the pool. As daddybug said, all you need to do is watch your CYA level. But at the same time, I expect CYA to require attention/lowering fairly soon.
    30,403
    Just a second, guys. There's truth to what the pool store is saying because of the CYA.
    His SWG pool probably carries a CYA of 70-80 and switching to pucks will drive it above 100 very quickly.
    So, yes, reduce the CYA to around 40 or so (by draining 1/2 the pool) and then you can use pucks the rest of the season.
    The alternative is to switch to liquid chlorine and live with the current CYA.
    So is there a way to lower CYA short of draining half of the water? Now I'm confused.
    Aug 2010
    Dallas, TX
    4,052
    No, but using liquid chlorine won't add more CYA, and you can learn to live with your CYA at its current level. Of course right now this is all speculation, a good set of test numbers would help. It is even possible you've been running on little or no CYA and that is what contributed to your salt cell's continuing problems.
    Sep 2009
    Greentown, IN
    914
    Find out what your cya is right now and go from there. If you can handle keeping your FC at the levels the pool calculator recommends for the season w/your cya where it is by using liquid chlorine go for it. If you're set on using pucks, do the testing first, but I'm guessing you're going to have to drain to get your cya levels down or they will get too high quickly.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    I am curious as to why 4 SWG systems failed. If the CYA level was too low, the unit would never keep up the needed levels of chlorine. If the ph were too high, due to TA high maybe, then the water would be harsh and possibly damage equipment or the cell I am guessing. What else could go wrong? High CH causing scaling? Hit by lightning? Chewed by the dog? Just wondering.
    Oct 2010
    Georgia
    317
    Which brand of Salt System?
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
