Thread: Installation of my Intex Ultra AGB
    I put together my Intex Ultra Frame AGP yesterday and filled it. I watched the water fill and moved the legs as needed to keep things plumb. What I didn't prepare for was the last foot or so of water really caused my legs to get a little out of wack where the "T" meets the leg, the T is kind of pushed in and there seems like a ton of force on it. I'm only about a 1/2 inch off all the way around the pool so I don't think being level is the problem. Is this going to be a big concern? Just about all of them are like this and it seems like the middle of the pool is pushing out on the legs quite a bit.
    1) 7500 Gallon Free Form Gunite Pool / 800 Gallon Gunite Spa
    2) EasyTouch 8 Automation / IC20 Intellichlor
    3) Intelliflo VS Pump for pool and water features - Cartridge and DE Filter / 2 Speed Pentair Pump for Spa and Cartridge Filter
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Installation of my Intex Ultra AGB
    Maybe the feet are too close? Can a big burly person lift a little while a less burly person pulls the feet out an inch or whatever is needed? It isn't easy but it can be done. We did our leg fixing that way, I got to be the leg puller cuz my burliness is kinda lacking...
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
