Thread: Trying to figure out head pressure. Convert to 2 speed motor
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I've posted some pictures on another post of my piping setup.
    Trying to figure out Head Pressure.
    With a new filter my system is showing a 2.5 PSI.
    I'm getting what I consider good flow.
    All piping in 1.5 inches.
    Main drain and Skimmer feed input to pump.
    return line has 2 tees. first Tee feeds 1.5 inch line that feeds 2- deep end returns the other side of the 2 feeds 2 gate valves that feed 1.5 in line that feeds 2 returns each. They have lower flow the further they are from the pump. (Makes sense, longer runs= greater resistance.)
    Can I swap out the motor and put in a 115V two speed pump. My system is set up for 115V. What motor would you go with? Or should I replace the whole pump?
    This is the motor that is currently installed:
    Would it be worth changing out to a 2 speed motor? I don't have water features and I manually vac the pool.
    Re: Trying to figure out head pressure. Convert to 2 speed m
    Unless your electric rates are really high, it is almost never worth switching out a working pump purely on the basis of financial savings. You could easily switch the motor for a two speed motor, but it will usually take a very long time for the electrical savings to pay back the cost of the upgrade.
    Apr 2011
    Murrieta, CA
    2,360
    Got ya. If it isn't broke don't fix it.
