Results 1 to 7 of 7
Thread: Vinyl Liner Stains
    Vinyl Liner Stains
    New pool owner - started noticing blackish and brownish stains on IG pool liner - numerous, some small, some larger. Seem to get a bit lighter when I shocked. My chemistry is good. Tried scrubbing and running a chlorine puck over it - nothing. Is it algae? Is it organic? Please help. detracts from looks of pool.
    36K IG Vinyl, Hayward Super 1.5hp, Hayward DE4800, Dolphin Robotic
    30,421
    Re: Vinyl Liner Stains
    Welcome to the forum!
    If you've been reading any of the other posts, you know the first thing we ask for is test results. Can you give us some current ones?
    Thanks for your reply. I just tested the water. FC 5, pH 7.6, TA 130. My test kit does acid demand which was 2 and it said I should add muriatic acid. Any thoughts?
    30,421
    Hold the chlorine puck directly on the stain for a couple of minutes. See if it lightens up some
    If not, crush up some cheap Vitamin C tablets, put them in a sock, then hold that sock directly down on the stains for maybe 3-4 minutes. Tell us the results
    Thanks again for quick reply. Don't have Vit C tabs (take a multi ) but tried the chlorine puck for a couple of mins and it definitely lightened the stains. Had tried previously but was afraid to leave it on too long so no noticeable difference. This time after 3-4 mins noticeably lighter stains. What's up with that?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    It means your stains are organic in origin rather than from metals.
    30,421
    That means the stains are organic and elevated levels of chlorine plus frequent brushing will remove them.
    My assumption is you cannot test for CYA.
    Before we suggest a level to bring your FC up to (and hold it there) we need to know your CYA level. Take a sample to a pool store to get it tested or, better yet, take charge of managing your own pool by purchasing a good kit that will test for everything you need.
