Results 1 to 14 of 14
Thread: Added Salt turned water green
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    New to the board, just discovered this BBB method, which I'm using this season, and it seems to be going fairly well so far. Water was nice & clear yesterday until I added salt.
    I searched this board for salt and green and didn't turn up anything. I just added salt to our pool yesterday, and this morning, the deep end looks a weird green. My son said it looked that way last night. I put 3 quarts of bleach in after the kids got out.
    A Google search turned up an answer on Yahoo saying it was probably due to a high metal content in the water.
    I ordered a better test kit which should be here this week. I hope I can read the chlorine levels better with it because a lot of these test kits, new or old, the top 3 levels look about the same.
    As it is now,
    FC is somewhere between 3 and 5?
    ph 7.8
    TA 130
    CYA 110
    Salt 2080 ppm
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    22,551
    Re: Added Salt turned water green
    Adding salt wouldn't have had anything to do with the pool turning green unless it wasn't pure salt. If it had additives or impurities that could have caused it.
    Is the water clear green or is it cloudy?
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    It's clear green.
    I used 99.8% salt tablets for water conditioners without rust inhibiters.
    Tractor supply had them for $4.49 for 40 pound bag.
    http://www.tractorsupply.com/home-impro ... lt-2189761
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Not sure if you can tell much from this pic
    K-2006 Test kit
    Apr 2009
    Burlington, ON, Canada
    344
    Here is the MSDS for Sure Soft Pellets Plus http://www.nasalt.com/images/stories/PD ... update.pdf
    It says sodium chloride 90-100%.
    You CYA is high, and your PH a touch high. I don't think that has anything to do with the green though.
    You also added bleach - maybe it was the bleach not the salt that caused the green?
    I can definitely see the green in the deep end.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Another
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    On the bleach, it's the same brand/type I've been using for the last month.
    On another note, in the past I've had problems with algae embedded in my ladder steps in the shallow end. The steps need replaced as they're getting old and the surface of them are rough which is causing the stuff to go deep into the surface of the step.
    K-2006 Test kit
    Try lowering the PH to around 7.5 and see if that has any effect.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    My K2006 came in today, so I finally got some meaningful readings. Since my CYA is so high, apparently I wasn't keeping the Chlorine level high enough. dumped in 12 3-quart bottles, and the FC is up to 29, the cya chart says shock level is 39, so I'm wondering if I should dump a few more in, esp since we're getting rain tonight, but I'll leave it at that for now and take another reading in the morning. I also added 1/2 gal of acid to try to bring the ph down, of course adding so much bleach has raised it up to 8, so if that doesn't come down soon, I'll put the other 1/2 gallon in.
    FC: 29 (after bleach, 0.5 before)
    pH: 8.0 (after bleach, 7.6 before)
    readings before bleach
    TA: 180
    CH: 90
    CYA: 100+ (110-120)
    CSI: -0.28
    K-2006 Test kit
    Nov 2010
    Calera, Al
    271
    With high fc your ph readings are prone to be inaccurate.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Chlorine reading this morning is 18, so it fell 11 points. (but we had some rain too) Slightly less green this morning.
    Back to the calculator!
    K-2006 Test kit
    22,551
    The fact that it fell that much overnight even with rain says that you need to shock. With a CYA of over 100 my suggestion would be to drain and get that down to a manageable level and then shock. It's going to take a lot of bleach to hold a FC of 39 ppm for any length of time at all.
    What was your CC, just for grins?
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    CC was .2 (before starting shock process)
    After putting in 24 more quarts this morning, the green is 90% gone... progress.
    Ya, the high CYA is making this project a little pricey. I told the lady at Aldis they were about out, and they needed to order more.
    I also need to find a plastic recycling place. I have a LOT of jugs.
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Pool started looking much better a few days of bringing the CL level 3x than normal. Because my CYA was so high (was 110-120, now 90-100 range), I never brought my shock level to 40 (So many jugs!), so it probably took longer to bring the FC to zero, but it's finally there. I've attached my readings, it took almost a month to get it to completely stop. Water temp is hot, so I've had to put a sprinkler head on my return to try to cool it down, so I'll have to watch my Ph.
    Since it's late in the season, I'll just deal with the high CYA for now, and having to put a large bottle of bleach in every day, and I'll exchange more water before opening next season.
    Pump runs from 8pm to Midnight, and again from 6AM to 10AM.
    The first night, I lost 11 points, then 8.5, 3.5, 2.5, 1.5 then I ran out of Titrant from doing 3 tests a day (after sundown, after bleaching, then morning after), ordered more Titrant, so had to add bleach without test kit, which caused me to lose some ground, but finally made it.
    Water continues to look good, no CC's. (I mislabeled FC as TC on the chart)
    Can't believe after 10 years of having pools, I just now am starting to learn how to treat them right.
    K-2006 Test kit
