Results 1 to 11 of 11
Thread: Consistently rising pH
    Over the last month the pH in my pool has been consistently rising to the point where I need to add Dry Acid on a weekly basis. My numbers are below:
    • FC/CC: 3.5/0
      TA: 100
      CH: 200
      pH: 8.2
    I live in the Northeast where we have had some rain but I don't think it's been more than in past seasons and I don't remember having this issue before. Any ideas why this happening and any ways to prevent it?
    25K Gal, IG gunite, Hayward 1HP pump, Hayward DE filter, Pentair Mastertemp 250, TF100 test kit
    Re: Consistently rising pH
    Rising PH is almost always due to higher than ideal TA levels. If you bring your TA level down to around 70, PH increases should stop, or at least slow down dramatically.
    Feb 2008
    Denton, TX
    5,061
    It is not that unusual to have to lower pH once a week. You can try lowering your TA as this should help buffer the pH rise to a certain degree. here is the process...
    pool-school/lowering%20total%20alkalinity
    Switiching to muriatic acid would probably help your case as well.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Lower PH to 7.4 with Muratic acid which will also lower TA. TA at 100 is a bit high if you are using Bleach or a saltwater generator for chlorination and may be causing your PH to rise.
    Thanks all. I thought 100 TA was good, guess not. So it sounds like I want to lower ph to around 7.0-7.2 and then aerate to raise ph. One more question though when I enter all this into the pool calculator it tells me to add 100oz of dry acid but at the bottom it says 100oz will only lower ph by something like .67. Which is correct?
    Feb 2008
    Denton, TX
    5,061
    If your pH is 8.2 and you want to lower it to 7.4 with dry acid, then I calculate using the Pool Calculator that you will need 69 oz. of dry acid to get it there.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    We prefer MA over dry acid, especially when lowering TA as it add sulfates over time.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by dmanb2b
    On top of the fact that it is cheaper and easier to dose as well.
    Does anybody have any suggestions on where to get Muratic Acid online? My local leslie's store does not carry it and their website says it's sold in the store only. I see a lot of pool company websites that sell pH reducers that they claim are "better than Muratic Acid" but can't find any that sell actual Muratic Acid. Any suggestions? I have been using Dry Acid instead but given the thread above wanted to switch and try out the MA....thanks!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Radiation, HD and Lowes sell MA.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    22,548
    Most of the big box stores have it but it may not be in the pool section it may be in the paint section or the cleaning section.
