Thread: SWCG still recommended?
    Mar 2007
    Houston, TX
    167
    Wondering if SWCG is still recommended for a new pool build we are planning. I had a pool built about four years ago at a previous house and we used a SWCG back then. Are they still recommended? Is it possible to have lower maintenance with just a standard rainbow style "puck" auto chlorinator? One PB suggested using sodium tetra borate which I believe is just borax and a STD auto chlorinator instead of a SWCG. I'm wondering if I should bother with it this time.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: SWCG still recommended?
    Still recommended.
    You may have lower maintenance with a puck feeder for the first couple months, but after that...... whoo, boy! One of the most common reasons people search for information and end up here is because they have a clkoudy or green pool caused by too much CYA, which is caused by those convenient pucks.
    If you used a SWG before and were happy with it, stick with it!
    Feb 2008
    Denton, TX
    5,061
    Agree with Richard320. A SWCG system is far superior to any tablet feeder setup that you will find. Go with the SWCG.
