Thread: Polaris 280 Black Max
    My polaris all of a sudden stopped working. On initial exam I noticed one of the wheels was not straight. The bearings seemed to be lose so I replaced both sets on that wheel. I thought that would do the trick, but the sucker won't move. It also lists to one side and doesn't seem to want to stay flat on the bottom of the pool.
    Recently my pool guy said my booster pump was leaking...it looks like he replaced the impeller and o-rings.
    Any thought?
    PebbleTec pool with beach entry and rock waterfall/slide, Jandy Aqualink Wireless OneTouch, Hayward DE Filter, Goldline SWG, Polaris Black Max 380 with booster, Hayward Heater, 2 Blowers for HotTub
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Polaris 280 Black Max
    Are the wheels spinning at all?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    No.
    BUMP!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I'm guessing that the drive shifts are not engaging the wheel fully. Also you might want to see if the spin freely, there are bearing that may need replacing. Also have you disassembled the shell to make sure the hoses are good and not cracked or off? This will also get to look at the drive gear to see if it spins on the shaft.
    Aug 2007
    near the swamp
    806
    any teeth on the wheel?
