Thread: adding chemicals with a variable speed pump
    Oct 2010
    Houston, TX
    152
    So, got an Intelliflo VF recently, and had a question about adding chemicals. Do I need to increase flows when adding chemicals? I have the flows at 15gpm, sometimes less. Can I just add chemicals over a low flowing return without changing speeds?
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    22,550
    Re: adding chemicals with a variable speed pump
    As long as there's a decent flow out of the return it'll be fine.
