May 30, 2011
40
This may be a really dumb question but I'm new to the pool world. A couple of you advised me to add borates once i get my ph down. I think I'm finally down to 7.2-7.3 but because of my infinity edge, waterfall, an spa spill overs I get a ton of aeration. How do I add borates and where do I get them? I'm assuming the pump on when I add them? And how long do we delay swimming after I add? If it helps my teat results are as follows:
Fc 4
Ta 110
Ph 7.3
Cya 55
Salt 3200
Ch 300-320
It seems like I'm having to add 1gal per week of muriatic acid to keep my ph down to 7.3 range
Thank you in advance
What is your fill water TA level?
Lowering TA slows down as the TA level goes down, because it takes longer to raise the PH back up. If your fill water TA level is fairly higher, that might provide enough time for topping off the pool to bring TA back up a bit.
