Thread: Pool at Home - Family away on vacation. Best Way?
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    What is the best thing to do with the pool when gone for a week?
    I use Pucks and have the feeder at the pump. The feeder is turned all the way to 5, But with the super HOT weather we have had I've added about 20oz of Clorox to the water every evening to keep the FC at about 5
    I have a friend who will stop by once or twice while we are gone, but probably won't run tests to get levels and figure out what to add. The biggest think he'll do is add water to the pool so it doesn't get low past the skimmers and pull air.
    I could have the friend add clorox each time. Probably just dump some in, not measure..... Maybe half of a gallon jug? Or just let the auto feeder do what it can and cross my fingers, my FC level shouldn't ever reach 0?
    What do most people do when leaving home? Especially those that only use Clorox and don't have the auto feeder at all?
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    30,414
    Re: Pool at Home - Family away on vacation. Best Way?
    How high is your CYA now?
    How much FC are you currently using on a daily basis?
    If you are going to be away for a week, it is best to cover the pool, if you can. Adding a fixed amount of chlorine can work quite well if you figure out an appropriate amount of add. Generally, it is safest if you have them add too much, rather than risk it being to little.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    My CYA is around 60 or 70.
    When I test in the evening my FC is around 3 with the puck feeder at the pump all the way open. I'm adding 20 or so ounces of 6% clorox each night to get it to about 5. I'm not sure how much is really going in since the pump is feeding pucks all day.......
    Jandy 2 speed pump
    30,414
    Time to pull the pucks out of your pool. If you don't, your CYA will become too high and your pool will become very difficult to manage.
    Next, Have your neighbor add one SMALL jug of Clorox each evening...that'll give you 3ppm daily and should have you covered.
    If he can only get by every three days, make it three small jugs but daily is better.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    I'm thinking I'll switch to just Clorox after we get back in town.
    Jandy 2 speed pump
