Thread: CC Keeps Climbing After Shock
    Had pool perfect and then power was off to my house for a week. finally got the pump back on a few days ago but haven't been able to get chemicals back on track yet. Have shocked pool last three nights as well as had chlorine tab feeder running. Combined Chlorine keeps rising. It was 2 on Friday and now 3.5 today. Pool is clear, just not sure how to the CC level back down to .5
    Current Readings:
    FC 2
    CC 3.5
    pH 7.8
    T/A 120
    CH 270
    CYA 0
    I know I need to add stabilizer, but any other suggestions would be appreciated. Also, pool should be safe to swim in, correct as FC is ok even though a little on the low side?
    Thanks for any advice.
    Michael, 35,000 Gallon, Inground, Vinyl Liner, Pentair CCP 520 Cartridge Filter
    30,421
    Re: CC Keeps Climbing After Shock
    Read "How to shock your Pool" up in Pool School. I recommend you follow that procedure and that will get rid of your CC's (which you need to do.
    I would also put in enough CYA to get to 20-30ppm before shocking so the sun doesn't burn off ALL your FC.
    Butterfly's Avatar
    South Carolina
    10,045
    No, you don't want to swim in your water. As Dave said, you need to shock, but get CYA in there at the same time.
    Your shock level is 10 for now.
    24 hours after your CYA dissolves, increase your shock level based on the amount of CYA you added.
    You're done SLAMing when:
    Thanks. Will follow advice. Much appreciated.
