Thread: LIMESCALE ON THE WALLS OF MY POOL-----URGENT! I NEED HELPP!!
    I need the fastest and easiest way to remove limescale of the tile walls of my swimming pool. I have tried Pressure washer, brush all sorts. the only thing i have managed to get it of with is a metal scraper, but this was cant be used as it scratches all the tiles... ANY SUGGESTIONS!????
    DrummerDan in San Antonio, TX, 55k gal, Rectangular in ground plaster, Single speed pump, Giant sand filter, Manual chlorination through tabs in skimmer basket and tab floater (move to bbb in progress), Kleen Machine robotic pool cleaner ran about twice a week
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: LIMESCALE ON THE WALLS OF MY POOL-----URGENT! I NEED HEL
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    It would take thousands of dollars in CLR to clean that up! I haven't used it but my neighbor had his pool cleaned with soda blasting. It got rid of all the calcium scale and did no damage at all. Scale is a real problem here in Tucson. His was pretty bad, but not as bad as what you are showing, and I think cost was around $400.
    chiefwej
    You can remove it with a diluted muriatic acid mixture, or if you are in a hurry and don't mind renting equipment you could use a plastic bead blaster.
    I am having the same problem, I looked online and found that the pros use a soda blaster. I had a guy come out and give me a price to clean mine ($560.00) I told him no thanks. I looked at harbor freight online and found that you can purchase a soda blaster for around $100.00 and a 50 pound bag of baking soda for around $35.00. I will be doing mine myself and saving about $400.00. there are videos on youtube on how you do it. It looks pretty simple.
    Good luck, hope this helps
    30,427
    The forum will be VERY interested in that outcome. If either of you use it, would you please post back the results?
