Results 1 to 11 of 11
Thread: How to change speeds on 2 speed pumps?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    I installed a TriStar dual speed 1.5HP pump. I have it running on the low speed but would like to connect it up so I can select low or high speed as I need high speed for vacuuming.
    Do I need some sort of controller to switch speeds? Nothing came with the pump.
    Apr 2011
    Ohio
    97
    Re: How to change speeds on 2 speed pumps?
    Hmmm, do you have a switch that you use, to turn it on and off? My Hayward 2 speed, has a toggle switch, almost like a light switch, but it goes in three positions. Left is low, middle is off, and right is high.
    14.6K gal., 24ft, 54" above ground. 2HP, 2speed Hayward pump (4psi low, 18psi hi), 150sqft cartridge filter. 4x20 solar panel (6 psi).
    Mar 2011
    Lower Bucks County,PA
    65
    ??should be a toggle switch next to service plate.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Apr 2011
    Ohio
    97
    No, I meant a switch on the pump itself. My pump, has an on/off switch right on it. Was just wondering if they all were that way. Depending if I flip that switch to the left or right, it is on hi or low.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    This may not answer your question but it may be a solution to your issue. I gather you want to switch speeds for the vacuuming process without having to walk back and forth between the vacuum setup and the pump?
    We wired an additional on/off switch and mounted it on the pool deck near the skimmer basket. To vacuum, I set the switch on the pump to high. Then I turn the pump off on the deck mounted switch, set up my vacuum equipment, and turn the pump back on, running on high now. When I'm done vacuuming, I turn the pump off, disassemble the vacuum, turn it back on, then walk over to the pump and set its switch back to low.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mar 2009
    Huntsville, AL
    156
    I'm not familiar with the pump motor (or operating voltage), but maybe this thread will help:
    http://www.troublefreepool.com/dual-...on-t14547.html
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by Drayken
    what model Hayward do you have? I was expecting this Tristar to have a switch on the pump so we can select high speed for vacuuming. thats all we need. now I hear we got to buy a $250 controller to change speeds.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by wimpy
    Thanks for all the replies guys. service plate? wheres that?
    the manual is completely useless..just has warnings all through it and thats mostly all.
    You don't need a controller, unless a controller is required to qualify for a rebate or there is some other reason to have an automation system. All you need is a switch. Many two speed motors come with the switch already installed on the motor housing, but not all. If your pump didn't come with a switch, you can always get a switch and mount it in an electrical junction box. You need a single pole double throw switch, typically a center off switch is used. The center/common contact is hooked up to one of the hot wires and the two side terminals are connected to the high and low speed terminals on the motor. The other hot wire goes directly to the common terminal on the motor.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks Jason. This would save us some money. I will get my electrician to install a switch. Many thanks!
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks again Jason. you really are a wealth of knowledge! I'm getting that switch installed. trying to keep cost down for my clients and this is a great solution. I need to hire ya!
