Results 1 to 12 of 12
Thread: Hi All
    Hi All
    I am a new user up in wisconsin. I found your site today because I need to switch out my Ecosmarte system to chlorine and I need some help. Does anyone know the proper steps to do this?
    Thanks!
    20x40 IG Vinyl,40,000, Pentair Tagelus TA60 sand Filter, Whisperflo pump 1.5HP
    30,400
    Re: Hi All
    Hey, KAB,
    Welcome to the forum!! Start in Pool School. Read the basic articles and that will prompt lots of questions.
    You will need a very good test kit. What kind of testing do you do now? How does your water look now? Why are you switching?
    Plenty of people here to help you get the job done easily.
    Feb 2008
    Denton, TX
    5,061
    Re: Hi All
    Welcome to TFP!
    nutjob's Avatar
    May 2011
    Dallas
    109
    Re: Hi All
    Welcome, friend. Prepare for lots of reading and eye-popping insights!
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    Re: Hi All
    Thanks fo r the welcome! I have been in "pool ****" for 3 years and would really like to move on. I do need some help though.
    My current levels are Copper .7,PH7.0,CH 300,TA 19. The water is kind of gray. I did read a past link from someone who talked about switching over to chlorine from their Ecosmarte system but it really was not very descriptive.
    I am draining out half the water and getting some new . I have ordered some Iron free to put in the get rid of the copper. I have read the pool school but I am kind of confused about what I should do after that. I did order my TF100 and hope that it will get here soon.
    Can someone help me with some proper steps? I would really appreciate it!
    22,537
    Re: Hi All
    Once you drain and get your new kit, run the tests and post the numbers. Converting is easy.
    Once you post the numbers we can provide you help.
    Re: Hi All
    Ok,Thanks bama. When I get the new water do I put in the metal free and circulate it? Do you know how long it takes to work?Do I wait to add in any bleach? Thanks!!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Hi All
    Welcome to TFP!!
    Follow the directions on the metal out bottle for dosing, thay should include pH and chlorine levels for using it.
    PLEASE have a touch of POP (Pool Owner Patience), I know you want it fixed right now, but undoing 3 years of Eco-Smart isn't going to happen overnight and rushing things might end you up with other problems
    You found the right place to help you with your pool , please heed our advice, the process will be quicker
    Luv& Luk
    -Ted
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Hi All
    Welcome to the forum KAB. You came to the right place!
    Essential Links:
    Re: Hi All
    Ok. I have another concern. I got new water today. I put in the Metal Free. I went to go put it on recirculate to get the metal free to move around and I realized that might not be a good idea. I still have my Ecosmarte chamber with the copper bars in it. My pool guy cannot come until next week. If I start it up to recirculate the water won't it just go crazy on those copper bars and not be enough to take care of the water? Hmm. Does anyone have any ideas? should I try and remove the copper bars? I do not know how stable the chamber would be with just those screws sticking out in there.
    Thanks!!
    22,537
    Re: Hi All
    Go ahead and put it on circulate and run the pump. It'll be fine. They can take the bars out next week.
    Mar 2007
    4,160
    Re: Hi All
    As I told my friend Filix, the bars in the flow are no worse than a couple of pennies in the pool - as long as they aren't energized.
    Enjoy the pool and don't worry about the bars until they can be removed
    Luv& Luk
    -Ted
