Results 1 to 10 of 10
Thread: Waste port leaking after replacing gasket...
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Well, after installing a rebuild/repair kit for my multi-port valve I'm still getting water running out of waste. The kit included a replacement spider gasket which was fused onto the diverter. I had hoped the gasket would prevent an earlier issue where water was coming out of waste but now it actually seems worse!
    For now I have a rubber stopper in the waste port. This makes thing a pain though as I'm constantly removing and adding the backwash hose while I'm cleaning out the pool.
    Help! Should I try to work more on the valve or look at some sort of plumbing solution? If plumbing, what would be the best approach? Thanks all again.
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    22,553
    Re: Waste port leaking after replacing gasket...
    Did you lube the gasket, etc. when you put it back together?
    Did you check the webs for cracks?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Did the first. Not sure what you mean by the second other than that I did look the white gasket material over yes.
    22,553
    The partitions where the gasket seats in the valve. If there is a crack in the one that goes to waste it'll leak water through.
    What happens if you hold pressure down on the handle while it's leaking? Does it stop leaking?
    Quote Originally Posted by Onslow
    The gasket should not have been fused to the diverter. The gasket needs to be secured to the valve, and the diverter should move independently of the gasket.
    Support the site
    22,553
    James, the jacuzzi valve is built different than most others. The gasket is indeed molded into the diverter so you can't just change the gasket because it's not a separate part.
    South Central NJ
    3,192
    Some MPVs have the spider gasket on the base, some have it on the diverter.
    Did you use silicone to "glue" the gasket in place?
    Is the handle spring still strong enough to hold the diverter to the gasket?
    Scott
    Owner of - PoolGuyNJ LLC
    30,431
    Onslow,
    The algae returning to your pool in your other thread seems directly related to this thread.
    Keep you "story" in one place and it helps folks get a better picture of your problem and helps resolve it.
    OK, thanks for the correction.
    Support the site
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Sorry.
