Results 1 to 8 of 8
Thread: Skimmer Closest To Pump Sucking 90% Air 10%Water
    Jun 2011
    Northern Middle Tennessee
    32
    Help!!!!! we have a 20x40 double roman Inground vinyl liner pool that is 3 years old. 2 skimmers, main drain and 1 light. 5 foot retaining wall on side furthest from pump. Last fall we had all concrete decking and cantilever coping removed due to excessive settling (looked like a roller coaster in some spots); have not put new concrete deck down to allow for more settling since our builder backfilled with dirt and some gravel but mostly dirt on retaining wall side. To make a long story short we have suspected leak since pool deck was poured and we were dumb enough to believe our pool guy that an inch of water loss a day is normal. Took matters into our own hands and went looking for leak since no concrete.
    Findings:
    1: Hayward light body had large crack on top---applied two part epoxy that is holding for now
    2: Water still evident in this area even with light fixed on outside wall of pool
    3: 1 inch water loss in 12 hours with light fixed , dye test did not show significant findings
    4: Skimmer closest to pump is sucking tremendous amount of air even though adequate water level present
    ; Other skimmer is not doing this, just happened over night
    5: Excessive bubbles only in step jets (2) and not other jets (2) or thing you hook auto vacuum line to (sorry i don't know the term) ; running on main drain now with skimmers closed --bubbles still in step jets
    Note to self: You get what you pay for, it only costs you more in the long run
    What is going on????? We are ready to fill this night mare in with dirt
    20 x 40 Double Roman Cardinal Inground Vinyl Liner With steel Walls, Saltwater, Hayward Light, 1.5 HP pump,Sand Filter, Jandy booster pump
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Re: SKIMMER CLOSEST TO PUMP SUCKING 90% AIR 10%WATER
    First, welcome!
    Sorry to hear you're having trouble and anxiety. I had many sleepless nights during our pool build. I have no idea about correcting your problem, but some one here will chime in soon.
    Did you take pictures during the build? If so, posting them on a photo share site so the construction guys can take a look may be helpful.
    Wish I could help more. Hope all gets fixed so you all can get into the water!!!
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Apr 2011
    Lynchburg VA
    393
    When you say the skimmer is sucking air are you seeing this air suckage at the skimmer itself or is this evident when the water from this skimmer assembly reaches the pump?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Nov 2010
    Calera, Al
    271
    If you have a vortex in your skimmer causing it to suck in air,You could add water and see if you are able to get it to stop.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    22,539
    Re: Skimmer Closest To Pump Sucking 90% Air 10%Water
    Is the weir in the skimmer working freely and correctly.
    Jun 2011
    32
    Still waiting on a different pool company to come and give his opinion on what we need to do with our pool. Hopefully he will give us some new insight on what needs to be done. If only the weather would cooperate so he can do a full inspection.
    Jun 2011
    32
    Appears all of our problems stem from light niche that has been leaking like we suspected since concrete was poured . Light was not leaking at conduit like pb has been telling us for the last couple of years , no evidence of repair work in this area of light . What is evident are repairs unsuccessfully attempted inside niche to cover cracks and broken seal at wall ,niche junction . PB has blamed electrician for damaging conduit junction and causing leak , there is no damage .PB has never mentioned the cracks that he has been trying to repair. All of the leaking caused the improper fill under concrete and cantilever to settle . Yesterday we realized the deep end appears off level because the "A" arm turnbuckle supports were not installed and allowed the wall to tilt out towards the backfill area due to wait of concrete shifting. Of the 20 supports our specs called for we have 8 . We only had 1 support in the deep end and no supports around our steps . Very frustrated that this nightmare could have been prevented if someone had done the right thing and taken just a little pride in their work . Not sure what direction we will take now , discussing possible avenues of recourse . Huge Lesson Learned
    Apr 2011
    Lynchburg VA
    393
    WOW, I see a rebuild in your future! I guess the big question is whether there will need to be a law suit to get the build going or not. Seems like your builder tried to cut a few dozen corners.
    Pool School
    Pool Calculator
    Test Kits
