Thread: Is this the best heater for my pool?
    I need to buy a heater for my pool. Its 15' x 36" I need it to heat quick and when needed. Not so much as to maintain a constant temp day and night. Im looking at a Raypak Versa 130 propane heater. Id like to be able to get my temps from around 75+ in the early morning to around 85+ for swimming later that day. The pool is only around 4000 gallons. I live in eastern Canada so i can get a bit chilly in the evenings.
    Thanks!
    P.S. Great site full of information... I'll be a regular here now.
    Re: Is this the best heater for my pool?
    That heater should get you about 10 degrees in about 3 to 4 hours, unless it's cold and windy. Using a solar cover should help avoid excessive losses due to weather.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    [center:m34f3xbv]Why not something like this?
    Just kidding. [/center:m34f3xbv]
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Sorry I cant answer you on the heater, but as mentioned keeping it covered with a solar would do a lot if it get plenty of sun. I keep my cover on at night to save some degrees too. Its hot here, but I lose 4-5 degrees F even when we are warm.
    Essential Links:
