Thread: Cloudy water
    Cloudy water
    Let me start by saying last year my DE filter died. Local pool supplier installed a Hayward pro series hih rate sand filter {250lbs} I have 23,000 gal. in ground vinyl lined,I use smart shock clorine.I opened pool may 6th. I have had water balanced for over a month. I`ve had it tested every week. It took 4weeks to see the drain cover thru the cloudy water.now I can see the bottom but still a little cloudy. New problem , light brown silt steaks all over the bottom except at jets and drain are. I vacuumed 4 days in a row, every day it all comes back . Had same problems last year with this new filter.I`ve had the pool for over 20 years and I never had a problem like this . I think it`s the filter,supplier says no. HELP!!!!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Cloudy water
    Welcome to TFP That filter is a little small for your size pool, but should still eventually clear the pool with frequent backwashing. I have the same filter on a pool half that size. When you say well balanced, can you post a full set of test results?
    FC
    CC
    PH
    TA
    CH
    CYA
    Re: Cloudy water
    sorry, can`t. they give me a print out of what I need but no results of test.I test at home with drops and testing strips , both are testing spot on
    Re: Cloudy water
    I`m going back in Sat. I will get results.
