Thread: K-2006 Kit Question
    K-2006 Kit Question
    This is basic, but my first pool and first test kit. Pool is plaster, 22,700 gal. full sun in Houston. Water temp is 90 deg. CYA=60. I have an inline chlorinator feeding tri-chlor tablets. On the K-2006 Chlorine test, it says for 1 drop=2ppm , use the 25mL sample. I put two dippers of R-0870 and shake. Then add drops of R-0871, swirling until clear. Three days ago it was 16 drops, today 14 drops. Here is the question. If one drop equals 2 ppm then I am at 3.2 ppm and then 2.8 ppm FC. BUT the instructions say to multiply drops by 3 which would mean 16x3= 48x 0.2ppm= 9.6 ppm and 14x3=52x 0.2 ppm= 8.4 ppm FC! Which one is it in my case? Hope this question is clear.
    Thank you,
    Bluetec
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: K-2006 Kit Question
    Not sure I understand the x3 part, but when using a 25ml sample, each drop counts as 0.2ppm. You can also use a 10ml sample and each drop would count as 0.5ppm and save on reagents too
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Did the 3 come from R-003, the CC reagent?
    Anyway, you need to let those pucks dissolve and don't add any more. Even with full sun and Texas heat, 60 is getting up there on CYA.
    Apr 2009
    Burlington, ON, Canada
    344
    Without getting up out of my comfy chair to check my k2006, are you sure it doesn't say something like multiply the drops in STEP #3 by 0.2 to get the ppm? As far as I know there is no mutiplying by 3 for anything.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    "4. Multiply drops in step 3 by drop equivalence (Step 1). Record as ppm FC."
    I need to slow down and learn how to read. There is no 3X multiplier. My bad. I have 2.8 ppm FC with my chlorinator setting on 4/5. Zero CC. Learning...
    Thank you,
    Bluetec
