Results 1 to 7 of 7
Thread: The Pool Purifier Cartridge?? Nature2
    May 2011
    Jackson, MS
    27
    I opened the filter and pulled out the cartridge and it weighs nothing, so I am assuming its empty and needs replaced??
    We are renting this house and I am wondering how necessary is this piece of equipment? We are heading to the pool store tomorrow morning to get the water tested and I'd like to have some knowledge before I go in there so they don't try to sell me everything under the sun.
    The pool is looking great and I am so excited to get the water tested.
    Northern who moved to the south and now has a pool!
    25,000 gallon pool - plaster
    Purex Triton sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: The Pool Purifier Cartridge?? Nature2
    It's totally unnecessary.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Post your test results and we can get you on the right track Don't buy anything from the pool store, except maybe some liquid chlorine.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Feb 2008
    Denton, TX
    5,061
    I had the Nature 2. I pulled the cartridge out, got on board with TFP here, and never looked back. Save your money. Buy beer and pool toys instead of a Nature 2 replacement cartridge. All it does is add metals to your water which stain surfaces and turn hair green. You'll be glad later.
    Apr 2009
    Burlington, ON, Canada
    344
    Quote Originally Posted by 257WbyMag
    I have done the same thing. Since doing it, the staining I was getting on my white skimmer and pump basket and on my return eyeballs has NOT returned. Save yourself the $$ (roughly $100 where I live for a new cartridge) and do as 257WbyMag suggested - beer and pool toys!!! (although I'm partial to pina coladas by the pool)
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    May 2011
    Jackson, MS
    27
    Thanks everyone! The pool store didn't try to sell me anything!
    My results are below!
    TC 2.1
    FC 2.1
    pH 7.2
    Total Alk 120
    Calcium 250
    Stabilizer 115
    I will say that I cannot see the bottom of the deep end. We just added more water and are about to shock it again. How much shock should I add at this time?
    Butterfly's Avatar
    South Carolina
    10,045
    mjwilliams81, I deleted your duplicate post. Please do not post the same question in more than one forum. Butterfly
    Your CYA has gone from 75 to 115!
    Either testing error or it is being added to the pool in some form.
    If that CYA level is correct, you need to replace some water before you shock.
    You're done SLAMing when:
