Thread: Test kit arrived today...1st tests
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    My new TFT test kit just arrived, so (if I have done the tests correctly) here are the first results.
    FC 5.5
    CC 0.5
    TC 6.0
    Ph 7.3
    TA 80
    CH 400 (you have to chew tap water in Tucson)
    CYA 70
    salt 3200
    Borates 50
    Note: the Ph is low because I have been using acid and aeration to get the TA down from 220 where it was. Looks like I'm there.
    So other than keeping the aeration on until the Ph comes down, does this all look right?
    chiefwej
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Test kit arrived today...1st tests
    Looks great and PH at 7.3 is OK too, especially with CH at 400
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    You might want to aim a little higher when you add bleach - if you only have .5 spare FC by late afternoon, that's cutting it awful close. pool-school/chlorine_cya_chart_shock
    Otherwise, I'd say you did a fantastic job balancing the pool without a test kit!
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Quote Originally Posted by Richard320
    Ok, I'm a little confused. The chart you linked to shows a target FC of 5 with a CYA of 70 in a SWG pool. Since my FC is 5.5 @ CYA 70, am I not OK?
    chiefwej
    Richard320's Avatar
    Jan 2010
    18,985
    Oops, I missed the SWG part. It continuously adds chlorine, so nevermind.
