Thread: Lowering TA
    Jun 2008
    Texas
    132
    Lowering TA
    The last 12 months have been hot and dry. Since our fill water has 217 ppm CaCO3 my TA has been increasing. I want to decrease the TA and add more Borax.
    My current water test results are:
    FC = 4.0
    TC = 4.0
    pH = 7.6
    TA = 170
    CYA = 65
    Borates = 20
    CH = 230
    Salt = 3,400
    The water is crystal clear and sparkling.
    Is the TA lowered by adding acid or does the TA decrease by CO2 leaving the pool during aeration.
    Instead of lowering the TA by adding acid and then aerate to raise the pH to 7.6 can I lower the TA by adding acid and then raise the pH by adding borax?
    TIA
    30,000 gallon gunite in-ground with a spillover spa, Diving board and water slide
    Hayward 1 HP Super II filter pump, Hayward 24 " Sand Filter Pro Series using zeolite media
    Polaris 380 cleaner with ¾ HP booster pump, Hayward Heatmaster pool heater, AutoPilot DIG-220 Power Supply SC-60 cell
    Testing with the TF-100 Test Kit
    Aug 2010
    Dallas, TX
    4,052
    Re: Lowering TA
    TA is lowered by the acid, then you bring the pH back up with aeration. If you add borax, it brings the TA back up.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Lowering TA
    You'll also want to reduce TA before bringing the Borate level back up to 50. Borates slow the rate of PH rise from aeration.
