Results 1 to 10 of 10
Thread: What's the best way to 'clean' the plates?
    Jun 2011
    Opelousas, Louisiana
    13
    what's the best way to 'clean' the plates? I heard a mild mixture of water and muratic acid and just soak the entire cell. Is that correct? I have a Hayward AquaTrol unit.
    18 x 36 Aqua Leader Allegro
    Re: What's the best way to 'clean' the plates?
    You should only use acid to clean the cell if there is obvious white crusty stuff accumulating on the cell plates. When you do clean it mix one part of acid into four parts of water and soak the cell in that solution for as long as it foams up. When soaking, the cell should only be submerged far enough to cover the cell plates with the wiring and wiring compartment must be kept above the liquid. After soaking, rinse throughly with a garden hose.
    Jul 2007
    Brisbane, Australia
    874
    correct with regards to mixture, but wrong about entire cell.
    connectors should stay above the liquid or they will corrode
    if there is a lot of build up you can use soft plastic or wooden stick to poke it out
    whatever you do don't use metal objects, you will scratch the surface and damage it
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Not to hijack this thread, but Strannik, define connectors.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    May 2011
    Sacramento, Ca
    64
    On my Jandy 1400 cell, I did not want to submerse the whole cell, so I put a baggy over one end with a rubber band over the fitting to seal up the end. With the baggy side down, I stood the cell up in my garage sink and filled with the 4:1 muriatic solution. I filled it up until all the plates were covered with solution. My instructions said no more than a half an hour in the solution. My cell was completely plugged with calcium (I just bought the house so it wasn't my fault) so the mixture never quite stopped bubbling.
    In my case the cell was so plugged with calcium, the MA bath did almost nothing. My cell was completely plugged and not generating chlorine, so I decided to get Medieval on it figuring I was replacing it any way. I literally had to chip the calcium from between the plates with a brazing rod. It was the only thing I could find that was thin enough to chip between the plates. I spent hours chipping, Ma bath, rinsing with garden hose. Made slow frustrating progress, so then I fire up the Power washer and hit it with that. Just blasted the cell from one end and then the other, and the calcium started fracturing and coming out. Between chipping with the brazing rod and the power washer I got the plates 90% unplugged.
    Put the cell back in and it threw codes for a couple of hours and then cleared up and starting generating chlorine again. Bubbles out the pool return fitting like crazy when it is running. Been living on borrowed time for 3 weeks now LOL!
    Good luck.
    Charlie
    30,000 gallon in ground pool, Jandy 1400 SWG, Jandy valves and controls, Sta rite cartridge filter, Just added solar panels and Starite Inellipro variable speed pump
    I spent a lot of money on drag racing, good whiskey, and expensive cigars. The rest of my money I just wasted.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    It's best not to have to clean them at all. If you keep your CSI in the minus side you will just need to inspect and just run a garden hose through it. I've found pools with high TA tend to have pH climb so keep the TA low like 60-80 or until the pH locks in place and does not move. keep pH around 7.4-7.5 and CSI in the minus -0.2 seems good.
    the good thing about swg's is that its real easy to drop TA and quick. just keep dropping pH to 7.2 and TA will come down fast. When the pH seems to be more stable try to target 7.4 and then lock it there.
    Jun 2011
    13
    thanks for the feedback everyone. I think I have a game-plan now
    Jul 2007
    Brisbane, Australia
    874
    Quote Originally Posted by orthofish
    in this context - a place where a cell lead connects to a cell which is not sealed and will let acid get to the copper wires/contacts
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    Mine is threaded so i was just going to cap one end off and fill with either the acid water blend, or just use straight vinegar and cap the other end off. Vinegar will work too, just takes a little longer and its safer to work with.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    Jul 2014
    Mesa, AZ
    3
    Red face Re: What's the best way to 'clean' the plates?
    Quote Originally Posted by JasonLion View Post
    Have you tried White Vinegar yet? It takes about an hour to remove / loosen calcium and does not harm titanium like muratic acid does. Its also safer for the person doing the work. My cell is cleaned 4 times per year and looks and operates good as new. I'm sure the mfr's will have an issue with this since this could reduce the number of replacement cells they get to sell customers. They certainly cant claim that vinegar will damage the cell It would be fun to see them explain why though.
