Results 1 to 15 of 15
Thread: Anyone know what this can be?
    It seems like a dirtily substance.. When i brush it nothing comes up or if i vacuum that area. I am attaching a picture..
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Re: Anyone know what this can be?
    That looks like staining, rather than algae. Try holding a vitamin C tablet against a stained area for 30 seconds and see if the stain goes away or gets lighter in that area.
    just a regular vitamin c tablet?
    Bel Air, MD 21015
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by precator
    Yes, the cheap kind without special coating.
    You're done SLAMing when:
    didn't work. You did say 30 seconds correct.. Not 30 minutes?
    Bel Air, MD 21015
    Also I saw this guys link.. his stains look a lot like mine. But I did not see a resolution on his post. He did mention though that vitamin c did not help him much either..
    Bel Air, MD 21015
    Bel Air, MD 21015
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, 30 seconds. However, in my pool, the spot was kinda difficult to get to, so I smashed a few vit C tabs in a cotton sock and held it in place w/pole for a few minutes. Some tabs have an outer coating that may take a while longer to get 'melted'.
    Have you used any copper products in your pool?
    Quote Originally Posted by Butterfly
    No I have not used any copper products..
    Bel Air, MD 21015
    Anyone know what this could be? It is driving me nuts. It is all over our pool...
    Bel Air, MD 21015
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    The color is a little dark, but it sure looks like Calcium to me. Through the water, with plain white plaster, mine looks sorta bluish gray. When you see it exposed, it's more of a tan color. I posted a few pics a while ago in this thread: post228991.html#p228991
    Obsessive maintenance of CSI around -.5 has removed a lot of my scaling. I suspect I will be able to post an after picture by the end of summer.
    What is CSI? and how did you solve this problem. Mine looks very close to your pictures
    Bel Air, MD 21015
    Richard320's Avatar
    Jan 2010
    18,967
    CSI is the Calcium Saturation Index. It is a calculated value. Pool Calculator will do it for you, if you enter all the variables. See this thread and save me a lot of typing.
    Quote Originally Posted by Richard320
    My CSI was at 0.37 Prob way too high.. Looks like I need it to get to the -.05 correct at least to start removing the scaling?
    Bel Air, MD 21015
    Richard320's Avatar
    Jan 2010
    18,967
    .37 shouldn't be a problem. However, that's not to say it has always been at that number. When I got a test kit to check up on the pool service I sorta inherited with the house, pH was off the scale! And with the hard water here, scaling was inevitable. Since I took over, pH has been under control, yet the scale remains.
    Keeping CSI near zero will keep things as they are. I had to drive TA waaaay down and keep pH at 7.3 to get CSI down to -.5. Then I got a lot of rainwater, which reduced TA and CH a lot, and that's when things really started to improve. If you want to try my method, you will need frequent water testing, like every other day, lots of acid, lots of brushing with a steel brush, and periodic partial drains to lower the CH you have been increasing by dissolving scale. And a year or two.
