Results 1 to 8 of 8
Thread: Recommended Chlorine level - Target or Minimum
    My CYA is about 45 so my minimum chlorine level is 3 - 4.
    I add liquid chlorine each evening after testing with an TF100. Up to now if have been trying to add chlorine to get to 5 - 6 so it is back to 3 - 4 the next evening. Everything seem OK with bright clear water but I am now wondering if I actually should be trying to adjust so it falls back to the target chlorine level 5 - 6 (not the minimum level 3 - 4) the following evening. It seems if I target this higher level I'll use more chlorine (at a higher cost) as other posts suggest you'll lose around half the chlorine level to sunlight each day
    Feb 2008
    Denton, TX
    5,061
    Re: Recommended Chlorine level - Target or Minimum
    You are doing fine by adding enough chlorine that you end up at the target level for your given CYA at the end of the day and I personally wouldn't change that. This is exactly what I do. Now, you can certainly run the FC a little higher by adding more than you have been. You won't necessarily use more chlorine by doing this since with all else being equal, you are still going to lose the same amount of FC that you have before. What you will have though is more of a cushion than you did previously.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,648
    I think you've got it figured out! I dose up a bit higher for those weekend parties too.
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    I shoot for the higher side bc I'm in full sun from sun up to sun down. I like having the cushion!
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Diver's Avatar
    May 2011
    South of Boston
    450
    Quote Originally Posted by 257WbyMag
    i think technically there will be higher CL loss, since it's a percentage and not an absolute number.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Quote Originally Posted by Diver
    That is what is was thinking - the higher the initial FC - the higher the daily loss and daily usage.
    Seems it is a balance.
    We now have some warm weather with pool about 85 at the end of the day (solar heating). I am adjusting to FC 6 each evening and seems to drop to about FC 3 by the next evening - this seems to be working well.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Somewhere in the forum chem geek has a few posts about FC loss. I think it said something about the higher the FC the greater % you will lose during the day. I'll try to find the post.
    Love TFP? Become a
    TFP Supporter!
    The amount of chlorine you lose to sunlight over the course of a day is a percentage of your starting level, assuming all else remains the same.
