Thread: Managing high TA and PH climb with a SWCG
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello.
    I've read the post about adding Acid (drop the PH 7.0-7.2) then aerating to raise PH to lower TA. I don't need to aerate because my SWCG is doing a great job aerating. My TA is 135ish and it's coming down slowly. My PH climbs a .1 every 2 days or so. I'm using about a gallon of acid a week or so (80 ounces takes it down from 7.8 to 7.2).
    The pool calculator numbers are pretty close.
    The pool water looks and feels great. I'm thinking about building the acid adder I read about http://www.troublefreepool.com/homem...stem-t4174.htm
    Any suggestions?
    Re: Managing high TA and PH climb with a SWCG
    What is the TA level of your fill water? If your fill water TA is high, then setting up some kind of acid injection system is a good idea. If your fill water TA is low, then you just need to do this once and you will be done, so no point in making an acid injection system.
    Active aeration would allow you to lower the TA far faster, letting you add acid daily or even more frequently, and get the TA down to somewhere that will allow the PH to be stable in several day, instead of weeks.
    Apr 2011
    Murrieta, CA
    2,360
    Thanks. Working on it now.
