Thread: I would like to add some salt, how much
    I would like to add some salt to my 18k IG . Solar salt Diamond crystal 40 lb extra course water softner salt (7304) How many bags? Thanks Filix.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: I would like to add some salt, how much
    can-you-add-salt-t6006.html
    7 or 8 40 pound bags should do it. Pool Calculator says 7.5 to get your pool to 2000 ppm.
    Thankyou Richard. And thanks for the link! Filix.
