Thread: TFT...DPD R-870 Powder Question
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    This is a simple one.
    What exactly is a heaping scoop of this anyway?
    I'm finding that the results between the DPD and OTO test vary a bit.
    A picture would be quite helpful.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Butterfly's Avatar
    South Carolina
    10,045
    Re: TFT...DPD R-870 Powder Question
    One heaping (heaped up amount that will stay put without falling off before getting to destination) OR, two level scoops. They are about the same amount.
    You're done SLAMing when:
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    The OTO test IMHO is not very good and I can never tell the different shades of yellow. Also OTO tests for TC not FC and CC seperately, so results will vary a bit if CC is present. One heaping scoop is in fact a rounded scoop, but if the sample turns solid pink, you have enough powder in the sample
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Well I guess both of you explained it well enough that no picture is needed.
    I have never needed to shock the pool except on opening...I leave it up and uncovered during winter, 4 years now.
    Thank you TFP
    30,421
    I always think of the OTO test as checking for the presence of adequate chlorine. It's almost surefire for that. The FAS/DPD is virtually mandatory to complete the shock process and on days when you want to calculate something and need a VERY accurate result
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    After using the TFT for awhile now I can sort of see a trend as to how my chem. balances are and how my pool behaves.
    I lose about 2 ppm daily in CL with CYA @ 30
    TA is usually steady @ 100 and ph stays around 7.6-7.8
    I like my ph around the upper range because it reduces the eye irritation.
    All seems to be well, I just wanted to be sure I was testing with the DPD correctly as it is the most important test to me.
    Thanks for the responses everybody!
    Thank you TFP
