Thread: Borate and salt levels
    May 2011
    Los Angeles, CA
    228
    Forgive me if I am blind but...
    Where can I find the suggested levels of borate and salt levels in the pool?
    Can the TF100 test for borates and salt?
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    Aug 2010
    Dallas, TX
    4,052
    Re: Borate and salt levels
    No, you need strips for these. You can get them at the same time as your TF-100 for a discount.
    May 2011
    Los Angeles, CA
    228
    Quote Originally Posted by RobbieH
    NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOooooooooooo oooooooo
    Salt is optional if your don't have a SWG. The appropriate salt level depends on why you are adding salt. If adding salt for improved water feel, target 2,000 ppm. For a SWG, see your SWG manual. Borates are optional. The target range for borates is between 30 and 50 ppm.
    May 2011
    Los Angeles, CA
    228
    Sorry for disappearing for a bit...fell ill and just recovered...
    If i add borax then do i have the option to convert to SWG in the future?
    Thanks!
    Jun 2008
    Texas
    132
    Yes, you can use borax with or without the use of a SWG.
    30,000 gallon gunite in-ground with a spillover spa, Diving board and water slide
    Hayward 1 HP Super II filter pump, Hayward 24 " Sand Filter Pro Series using zeolite media
    Polaris 380 cleaner with ¾ HP booster pump, Hayward Heatmaster pool heater, AutoPilot DIG-220 Power Supply SC-60 cell
    Testing with the TF-100 Test Kit
