Results 1 to 8 of 8
Thread: correct pump size
    correct pump size
    I'm new to pool ownership/maintenance. The local pool store sold me a 2.0 hp pump for my 15x30 ag oval pool ~ 13,000 gal with sand filter. I've been reading that this is probably too much pump force and doesn't allow the sand in the filter to actually filter the water. I have cloudy water, PH = 7.8, Alkalinity = 120, total chlorine and free chlorine low, hardness high. I shocked it and CL rose to .4 over night. They keep telling me i need more of this and that and not one thng has changed the cloudiness At ALL. I'm thinking of getting a smaller pump- any recommendations about the pump or the cloudiness.
    Atlantic 18x33x52 (14,800 gal) AG. Waterway 2hp/2 Sp. 150 Cart Filter
    Re: correct pump size
    My pump is 2hp as well. On high it certainly does flow!, but I've never noticed it not filtering properly. The majority of the time my pump stays on low.
    Someone who has been BBBing longer would be much more help. I still have pool store stuff for pH and alkalinity.
    What type of test kit do you have? A good test kit is the foundation of BBB.
    I guarantee you the advice on here will take care of all your problems, welcome to the forum!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    thank you for a reply. I just bought a chemical test kit with the drops but have't used it yet. I actually have very small stuff floating in the pool. I used Krystal clear - that was supposed to coagulate and make flocualte to vacuum up- but that didn't do anything. I can only see down the liner about 4 inches. My return jet is pointed down ~ 45degrees and out to the side a little. I "bled" the filter to make sure there is no air in it. The BBB thing is so foreign to me- I think once I can get the pool clear- and to make sure its not mechanical I will attempt to switch over. But right now I've just got a cloudy pool that I don't know how to fix. Is it possible i have the water level too high and the skimmer/pump isn't sucking anything down. The big stuff is collecting in the skimmer basket. its the small stuff still floating around. Help!
    22,543
    You probably need to point the return eyeball up and as far toward the side of the pool away from the skimmer as possible. Mine works best pointed to where it barely disturbs the surface of the water and as far to the side as I can get it.
    Ok so I did a test - I attached a stocking to the jet return and within 40 minutes I have about 1 large table spoon of sand and particulate - now Im pretty sure my motor is too big- any suggestions before I buy a lower hp motor? Any other reason why this woudl be happening?
    22,543
    Too large a pump won't cause the sand to enter the pool. It can create tunnels through the sand and allow it not to filter well. Sand getting through the filter is a filter problem. It could be the multiport or more likely the lateral/standpipe assembly.
    its a new multiport valve- what kind of problem would I have with this/look for- before I disassemble the filter to check the pipe/lateral assembly
    22,543
    If it's a new top mount multiport that points to something happening when the valve was replaced. The stand pipe could be out of place.
