Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: High PSI on sand filter......
    After a six hour hard rain last night, these are my readings.
    FC 3
    PH 7.5
    TA 90
    CH 120
    CYA 40
    BR 40
    My sand filter (without DE, sand only) PSI has been 17 PSI clean and 18PSI dirty this entire year. Early on I had one day of 13 PSI. I acid cleaned the sand today and the pressure is still 18 PSI. The return water will almost float you away and blasts powerfully agaist my hand. The water stays crystal clear except today because of the storm. I should have it brushed and cleaned up later today.
    Waht do you think about the PSI?
    22,544
    Re: High PSI on sand filter......
    What size eyeball do you have?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Does the pressure go to zero when you shut the pump off?
    About the same size as your...LOL....seriously its a 2 inch gauge. The pressure drops to zero when the pump is off.
    I am thinking about adding the DE but I was concerned about the current pressure before I add something that will raise the pressure another 1 PSI.
    Aug 2010
    Dallas, TX
    4,052
    I just read this for the second time, and 17 clean and 18 dirty isn't right. Where did you get the info that a rise in 1 psi means it is dirty? 8 to 10 is more common.
    My filter has been in operation for six years. I replacement the sand at the end of season 4 and converted from Baqucile to chlorine. Four the last 4 years the lowest reading has been 15 PSI, 18 PSI dirty. Now it will not go below 18 PSI after an acid wash.
    Hayward PowerFlo Matrix 1.5 hp, Hayward Vari-flo XL Valve and hayward Pro Series High Rate Sand Filter Model S210T
    I talked to my pool supply and they said that I had the proper amount of sand, 150#'s to allow good circulation and they know that I have replaced my gauge once. They said to ignore the gauge and go by return pressure. I always feel the return flow anyway. Maybe I need a new gauge. The system seems to be working great as far as cleaning and function goes....
    brewtus's Avatar
    May 2008
    Knuckle of the Thumb in Michigan
    16
    I'm gonna go with a faulty gauge. I have the same pump/filter set-up as you, and my gauge had corroded and failed in 2 years.
    I don't know enough to even know what I need to know.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Not sure why you would acid wash a sand filter, other than just backwashing it, it may be possible the acid damaged the guage
    That said if your clean pressure is 15psi, 18 is not dirty, 22-25psi would be consider dirty. Every filter/pump combo is different...mine happens to run at 18psi clean.
    Should the gauge drop to zero with the pump off? Mine doesn't.
    31,000G IG vinyl 20X40 True L. Hayward 1.5 superpump, Autopilot Pool Pilot Digital SWG, Hayward Model S244T 300lb sand filter, TF100 kit
    Home Warranty just replaced my DE filter with a Sand Filter and it runs 18psi clean. The installer said that this is normal.
    Former Intex Owner, switching to 15,000 gallon AGP with Hayward E200 sand filter & 1.5 HP Power-Flo LX Pump.
    SW Indiana
    9,199
    Quote Originally Posted by jsw5620
    Yes it should.
    SW Indiana
    9,199
    Quote Originally Posted by DA INFERNO
    18 psi may be absolutely normal for one pool and equipment setup, but abnormally high for another. You can't compare a pressure reading for one pool with another.
    Quote Originally Posted by JohnT
    Yes it should.
    What does it mean if it doesn't?
    22,544
    jsw5620 -- It means that the gauge is broken. Or at very least that the zero is off and it shouldn't be trusted.
    Ptblues2 -- I was asking about the eyeball fittings in the pool. If you have a small one it'll cause your pressure to be higher than if you have a large one.
    LOL. I thought you were asking about the gauge. I will measure it later this morning.
    The eyeball is 3/4 inch. I have two the same size. Yesterday my return line popped loose and drained 5 inches of water from the pool. I am guessing the the pressure had something to do with it popping off. Anyway, I am balancing the chemicals again.
  20. Back To Top    #20
    22,544
    (2) 3/4" eyeballs should be fine but you could change them to 1" if you wanted to lower the pressure and increase the flow.
